Just recently I removed my soft top to change it for a dark blue one in better condition.
It is fairly straight forward to remove, but if it helps anyone, here is how I did it.
Firstly, if you have a windbreak, remove it. Mine is wired into the side lights so I removed it and laid it flat on the parcel shelf.
Next, unclip the two windscreen catch assemblies to release the soft top. This will make it easier to release the rear clips.
Now release the rear clips (x5) that hold the rear of the hood down.
The next step is to remove the bulkhead finisher (or T-bar cover if you prefer).
The cover is obstructed on either side by the door seals.
Open the doors and pull the door seal off until it is clear of the cover.
Next, you need to remove the 3 screws that hold the cover in place.
Just unscrew them with a cross point screwdriver and put them in a safe place.
The cover should then pull towards you. It will need a bit of a tug as it is held in place by plastic clips. Be careful as these are easy to break. I replaced mine with screws a long time ago as I have the cover on and off so often.
Once the cover is out of the way, you will find a bracket on each side. Each one is held on by 2 13mm bolts.
Undo these bolts
And remove the bolts and plate assembly on each side
The next bit is a 2 person operation.
Fold the soft top down and lift the rear upwards. You can unzip the window if you want to avoid it cracking or creasing. With one person each side, slowly lift the soft top clear of the car, taking care not to scratch the body work.
Place the soft top somewhere safe.
Fitting is a reverse of removal.
You may need to adjust the catch assemblies http://forums.mg-rover.org/showthread.php?p=3461825#post3461825 and side windows to achieve a good seal if you have fitted a different soft top.
Undo these bolts
