1 - 2 of 2 Posts
mg_zr
Can anyone point to any sites or pics on how to adjust front bumper? The point where the front bumper meets the wing above wheel arch needs a tiny adjustment on mine. Is this straight forward and where are the screws/nuts that need to be adjusted?
Thanks for any responses.
The only thing you can do really afaia, is to slaken off all the bolts across the top of the bumper, the two torx bolts at the front, and the two self tapers on each wheel arch, lift up the bumper with a jack at the front centre (use a piece of wood to spread the load) - very carefully, and only by hand - and then tighten everything up again, remove the jack. I'm pretty sure there is not much else you can do. Hope that helps.
1 - 2 of 2 Posts
