1 - 14 of 14 Posts
I reversed out of a friends drive yesterday, but failed to notice that the very right hand side of it wasn't dropped. I noticed when I felt the rather large bang as the right side of the car dropped onto the kerbstone. This has resulted in the panels seperating at the rear right jacking point, as if then been split with a chisel or something.
Since I don't want water getting it in and rusting away I was just going to fill the gap with some 2ton 24hr epoxy and then clamp in closed. However, I remember reading that this may be a structural area and therefore may need to be welded back together. Is it ok to just glue the two seams back to stop rust intrusion?
erm, which two seams are we talking about? the ones which meet at the jacking point, along the sill?
If so, and the sill is damaged, the only way to fix would be a new sill, stops the rust that way, and yeh i believe it is structural, and if your sills start to rust, will fail MOT
Discussion Starter · #9 ·
Right, its been given the once over by my local independant and hes going to take it in tuesday and repair it. He did however say that it wasn't serious or dangerous and to continue to drive it would be fine.
rover_45
I would have to disagree with that. It is dangerous the sill of the car is now exposed to the elements and it will also weaken the body shell in a crash. I WOULD not drive it like that and you best hope PC plod does not see it and pull you up as he will have you for driving an unfit vehicle. Have you every used the garage you are taken it to.
I've left my degree in metallurgy in my other jacket, but I think it's safe to say that looks pretty nasty.
Your local independent may well be right and I'm not going to second-guess him, but the fact of the matter is that any structural seam coming loose will compromise the car in an impact. Please be careful.
Don't get me wrong, I'm not slating your garage.
But I've had old-timers, who really know their stuff, tell me that the correct torque for brake carrier bolts is "...as tight as you can get it. Use your weight.". Yeah, right. This is the same bloke that changes fuel filters while smoking and thinks that hot tarmac is a good jacking surface. Other than that, he's diamond.
So while he may have reached a ripe old age without killing himself, there is probably an element of luck involved.
I'm not being over-dramatic, fella - If your mechanic says it'll be fine I have no reason to doubt him. Just be careful because you're dealing with (to you and most of the rest of us) an unknown. Hate to have you post here from the hospital.
Remember this - it's you in the car, not him.
1 - 14 of 14 Posts
