1 - 2 of 2 Posts
how do i fix a passenger front electric window on a rover 600ti 1997 r reg.
motor still works but when window is wound up it comes out of alignment and jams.then you have to pull it up by hand when you press the window button.
cheers,arnie
rover_45
You need a new regulator. The plastic things on it will have broken it's a well known thing on the 600 that these break. Admittedly they do last a good few years before they go. The only other thing you can check is the metal runners are straight and not bent.
1 - 2 of 2 Posts
