Status
Not open for further replies.
1 - 2 of 2 Posts
HONDA ECU Flash Code
If your 'check engine' light comes up on the dash, then look below:-
this is for the 216/416 R8 range of cars with ECU in the passenger side footwell, lift up footwell carpet and count the flashes
Short flashes for ones, and long flashes for tens.
1 Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor
2 Oxygen Sensor "B" defective circuit or unplugged / defective sensor
3 Manifold Absolute Pressure (MAP Sensor) defective circuit or unplugged /defective sensor
4 Crankshaft Angle Sensor (CAS) defective circuit or unplugged/defective sensor
5 Manifold Absolute Pressure (MAP Sensor) mechanical problem / disconnected piping
6 ECT Sensor (Engine Coolant Temperature) defective circuit or unplugged / defective sensor
7 Throttle Position Sensor (TPS) defective circuit or unplugged/defective sensor
8 TDC Position (Top Dead Centre Sensor) defective circuit or unplugged / defective sensor
9 CID Sensor (Number 1 Cylinder position) defective circuit or unplugged / defective sensor
10 IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor
11 CO pot (IMA Sensor) defective circuit or unplugged / defective sensor
12 EGR Lift Sensor (Exhaust Gas Recirculation) defective circuit or unplugged / defective sensor
13 APS Sensor (Atmospheric Pressure Sensor) defective circuit or unplugged / defective sensor
14 IAC/ISCV Valve (Idle Air Control/Idle Speed Control Valve) defective circuit or unplugged / defective sensor
15 Ignition Output Signal missing or defective ignition output signal
16 Fuel Injector System defective circuit or unplugged / defective fuel injector
17 VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor
18 Ignition Timing
19 Automatic Transmission Lock Up Control Solenoid Valve defective circuit or unplugged / defective solenoid valve
20 Electrical Load Detector (ELD)
21 VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve
22 VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
23 Knock Sensor (KS) defective circuit or unplugged / defective sensor
30 Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
31 Automatic Transmission Signal "B"
41 Primary Oxygen Sensor – Heater circuit malfunction on D16Z6, D16Z7, D16A2 engines
41 Linear Air Flow (LAF Sensor) heater malfunction on D15Z1 engine
43 Fuel Supply System defective or malfunctioning fuel supply system
45 System Too Lean or Too Rich malfunction in the fuel monitoring systems
48 Linear Air Flow (LAF Sensor) defective circuit or unplugged / defective sensor
54 CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor
58 TDC Sensor 2 (Top Dead Centre) defective circuit or unplugged/ defective sensor
61 Oxygen Sensor, Heated - Sensor 1 (Primary) high voltage, low voltage, or slow response
63 Oxygen Sensor, Heated - Sensor 2 (Secondary) high voltage, low voltage, or slow response
65 Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater
67 Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system
70 Automatic Transmission malfunction with the automatic transmission controls
71 Cylinder 1 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
72 Cylinder 2 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
73 Cylinder 3 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
74 Cylinder 4 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
75 Cylinder 5 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
76 Cylinder 6 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input.
92 Evaporative Emission Control System insufficient purge flow
Discussion Starter #2
If your car then has one of the problems listed above, please post about it in the R8 section if you're not sure where abouts that sensor/part is, to help you further in diagnosing the problem :)
1 - 2 of 2 Posts
Status
