When cold the car starts fine. Fires up straight away.
When the car has been running a while, and I stop at a shop or something, and the engine may have only been off a couple of minutes or so, when it comes to starting the engine will turn over, but then hesitate (as if I've left go of the key) but then fire up. It's a bit disconcerting, and I have no idea why it does this.
I've had quite a lot of work done to the car, including replacement cylinder head (which was pressure tested and skimmed) and head gasket set, cambelts and various other work on it. This work was all done really before I got to know the car, so I don';t know if the problem was there before or if it's a result of the work done.
Anyone got any suggestions?
The car can be a little bit mis-firey (only very slightly) if the weather's damp/wet and the car is cold and I try to accelerate hard in too high a gear. I realise this is probably the HT leads, but it's not stopping the car starting normally. And not only that it's only when the car is hot, and has been turned off a few mins.
