1 - 16 of 16 Posts
Hi guys
On returning from my early morning swim i pressed the button to shut the front drivers side window (which was half open) - it crawled a couple of inches then stopped - it was fine going down but will not go up - so currently it's sitting outside my house open - any ideas what the problem might be and the quickest way to resolve it.
Cheers, Scuzza
In the Garage
MG TF
If it wasn't making any odd noises then it could be that the window stop has broken. I would remove the door card and see what's happened, you may also be able to get the window back up with a temporary repair.
I had this problem, turned out to be the regulator. Hopefully yours isn't.
I took the door card off and just propped the window/regulator up with a 'stick' and some duck tape while waiting to get it fixed.
it's just odd that it goes down fine but not up - was this the same with you ?
Yep.
Maybe :)dunno:) it's cos the motor/regulator/whatever doesn't have to work as hard to go down cos it has a little help from gravity?
Mine went from going down but not up - to not doing anything at all, other than making a rather nasty noise.
Fingers crossed yours is an easy fix... :)
Yep.
was it a costly repair, did you do it yourself ?
Can't remember exactly how much it was - part (as new) is £249.95 on MGOC spares site - which is about what I paid as I recall... I didn't try to fix it, but it's possible if your handy. Garage did mine for an hour's labour. Bummer was it was one of the parts not covered by my warranty. :( ;)
Still, it may be something else/cheaper yet :)
In the Garage
MG TF
New window regulators can be bought from a company for around £150, can't remember who they are but a search on the forum should find them.
That's what I should've done instead of letting the garage order the part in... :doh: ...live an learn... then again, I thought it was the motor at the time... :lol:
Discussion Starter · #10 ·
are these not scrappy items ? and how will i know if this is the problem or is this the only think it can be ?
Thats how mine went, it turned out to be the window regulator, I got a Electric life one for about £90 the OE are over £200. It can be a ball ache of a job too. Oh also take it out the motor and give the pinion a twist before you change it mine jammed and i though it had gone but after a few weeks of not using the car it had jammed. just a though.
I think Best of British had some electric life ones in too
Discussion Starter · #14 ·
Hi
I took the door card off last night, how on earth do you get to the window ? It's just a series of small holes in the door panel. I fiddled around and eventually for some unknown reason it kicked in and closed, then i drop it down and inch and tried to do it up again and it wouldn't - could it be a lose connection ?
Discussion Starter · #15 ·
so, does anybody know if there is a process of elimination that will enable me to pinpoint exactly what this problem is, as i don't want to fork out 200 quid for a part if it was something more simple (a resistor or something) - ta
Discussion Starter · #16 ·
good news( i think) - i switched the switches over and now the other window doesn't work = faulty switch, bought one on ebay for £9 last night and hopefully, it will be a case of plug it in and job done, phew !!
1 - 16 of 16 Posts
