1 - 5 of 5 Posts
I was putting my kick builds in today just had one more screw to put in and then it happened, i drilled through the wireing harness of my car straight through the middle.
Im stuck on how to fix it now, i have conected all the wires back together, i only managed to damage about 4 and split abount 10, anyway they are all connected back together, i changed the fues and most of the things are working apart from when i switch my car on the abs light says on and when i take my handbrake off the light goes off but as soon as i drive it comes back on.
Does anyone have any ideas on how i can fix this.
And before anyone says it im a stupid bas**rd
snellgrc said:
sounds like some wires arent back together fully - how did you join them back up?
I put bullet conectors on them and joined the blue to the blue green to green ect,
The only one i had a problem with was a thicker black wire with 2 green wires inside totally cut in half im not sure what the wire is for,
Is the ABS and handbrake linked?
BTW Car is MGZR 120+ 2003
1 - 5 of 5 Posts
