Magnet attatched to some stiff copper wire that you can feed in to the tunnel and wiggle about (technical decription
) and retrieve the spanner?
Is that the part that scrapes loudly on speedbumps?Failing that you might have to take off what seems like the 100 bolts holding in the small central under pan.
Could give that a go - does anyone know whether Chrome Vadnium is magnetic before I rip a hard disk apart to get a magnet?Magnet attatched to some stiff copper wire that you can feed in to the tunnel and wiggle about (technical decription) and retrieve the spanner?
Damnit, I was going to sue you for £2 to replace my spanner :lol:my solicitors have suggested that I formally declare that I am not responsible in any way shape or form for loss of spanners or any other items whilst performing anything that I may or may not have posted on this or any other forum or web site on the interweb, this disclaimer also applies to bits of paper as well![]()
Actually, that raises another question... is anyone aware of anything in the transmission tunnel which could get jammed if a lost 10mm spanner was wedged into it?Buy a new spanner!![]()
The only thing that gets jammed in the tunnel and causes pain is your hand, I wouldnt worry about it, just get a new spanner but this time put a length of tape or string around it firstActually, that raises another question... is anyone aware of anything in the transmission tunnel which could get jammed if a lost 10mm spanner was wedged into it?
I'm not the sort of person who usually gives up, but I think I'll give up on this if Project Rapid Acceleration doesn't work. I just hope it doesn't rattle around too much - the last thing I need is another rattle or squeak!!The only thing that gets jammed in the tunnel and causes pain is your hand, I wouldnt worry about it, just get a new spanner but this time put a length of tape or string around it first
:fishslap: :lol:Buy a new spanner!![]()
nice movemy solicitors have suggested that I formally declare that I am not responsible in any way shape or form for loss of spanners or any other items whilst performing anything that I may or may not have posted on this or any other forum or web site on the interweb, this disclaimer also applies to bits of paper as well![]()
Tried itcoathanger? straighten it out and hook the end (wiv a bit of insulation tape wrapped around the tip to prevent scratches), wedge it down the seam a draw it front to back............
.........Then when that doesn't work, buy another spanner!
I dropped a heater knob down there when I changed my interior over (don’t ask).
I managed to (eventually) get it out using the coat hanger to manoeuvre the offending item and then a long screw driver with a lump of blu-tac stuck on the end to stab it and lift it out.
Good Luck!!
