Liam, are you talking rear lights or front? If its the rear then there is another connection in the driver side cluster that may have come dislodged. Without it they will not work.
Sorry, front lights i mean mateLiam, are you talking rear lights or front? If its the rear then there is another connection in the driver side cluster that may have come dislodged. Without it they will not work.
i may have to check the fuses then, maybe there are seperete ones, i have tried new ones and they dont work, do must be something else, hopefuly a fuse if they do seperate ones, will this be the fuse box in the engine bay or under the steering wheel?Liam I think LEDs need a resistor ballast in the circuit. I am not up on LEDS for cars but have read about these. Regarding your bulb not working now, try a new bulb as coincidences do happen and the old bulb may have gone. Check the fuses too just in case there are separate ones for you car. I know that MGR did change circuitry in various models from time to time.
yep okay i will try that, thanks mateI would say steering wheel. I assume that your bulbs are the wire end connectors? Pull the wires away from the glas slightly jut in case they are not making contact properly.
I am logging off now so will check tomorrow to see how you have got on.
