1 - 19 of 19 Posts
Hiya all​
Is your heater faulty? loosing the control of the heater fan speed one by one?
I've got a few more Modified Heater Resistor Packs for sale again.​
This item will fit into all rover 200 and 400 from 1989 - 1999​
All Rover 25's and 45's​
All MGZR and MGZS models​
I replace the flimsy pieces of wire that make up the resistance in the circuit and solder in place wirewound ceramic resistors to stop this problem happening again.​
Very simple to fit into place on all the above models, full fitting instructions will be supplied with the replacement part, it took me 30 mins to fit into my car (1999 200) and that really was taking my time to ensure job was done correctly.​
£15 + £3 recorded next day delivery.​
When i replaced mine i went to a salvage yard to get a replacement one and i was charged £20 for it so i feel this is very good value considering it is never likely to fail on you again.​
Hi ROVER218IS,
My heater has given up on my 1998 rover 200Vi. :(
Do u still have any "Modified Heater Resistor Packs" for sale?
Do u accept paypal?
p.s I need two if poss (my girlfriends is also busted).
Please reply to both of these emails to ensure I reply as repidly as possible.
[email protected] (home)
[email protected] (work)
Hope to speak to you soon
Many Thanks
Grant Rice (rover vi)
£40 each!!
Their only £26.69+vat from my local MG-Rover dealership. But thanks anyway.
I will give rover218is a week to reply otherwise will have to buy from Rover.
They can be repaired for little cost, or a couple of quid from local scrappy minimum price is charged???...because they cant test them to validate, worth a try.
grantrice said:
Ok cheers m8, will pop to the scrapys on the wkend. will let u know how much i pay and how i get on!
cheers!
You may need to visit a couple of yards. as they go as quick as dashboard clock/display units..good luck, yep! let us know how you go on.
I did mine myself using Technozens guide, cost about £3 for the resistors (I bought 4 incase I messed one up) from Maplins and about 15 mins with a soldering iron, then about the same for removal/refitting together.
Works fine, much sturdier then what was there and very cheap.
1 - 19 of 19 Posts
