can anyone help ?? my heater blower only works on speed 3 and 4 ? is there a quick fix for this or is it a big job does anyone know ??
thanks
In the Garage
MG TF
It's a common problem and you will need a new resistor pack for about £30 or it is DIY repairable if you are handy with a soldering iron.
As above, you need a new resistor pack. Spent ages searching our local scrappy for a replacement out of other rovers, eventually nabbed one out of a coupe but had to remove the resistor wires and fit into the base plate from the F.
Its a bµgger to get to on the F, mind! above the passenger footwell, remove the glovebox you need small hands and a small phillips screwdriver IIRC.
