Evening all,
Earlier today both my heater fans and *** lighter stopped working for my ZR. Is this likely to be a fuse that has gone? If so i have had a look at the fuses and couldnt see which one it may be (I am rather a techy novice as you may have noticed!!!)
All help welcome,
Evening all,
All help welcome,
have you got a haynes manual? if not, invest!
Check the under bonnet fuse box. A little pink fuse module had blown on mine, and I lost the fans and lighter.
Did you have something plugged into the lighter at the time, or were the fans on?
If you replace the fuse without sorting the problem that might exist, the it could blow again. In my case I had shorted out the lighter, so I knew the cause.
