I am new here so any help would be appreciated.I have a BRM and having problems with it pulling off heavily to the right. This only happens when accelerating hard and engine breaking, during normal driving conditions it goes pretty much in a straight line.
There was a "four wheel alignment done on it last week to no avail.
Any ideas?
has it always done this - or only recently?
sounds like there is a bush/mount gone somwhere - this wouldnt come up on a static wheel alignment check.
I would take it to a proper garage who will be able to get it up on the ramps and have a look around.
There is a trailing link on the front suspension which if the bushes have gone or are worn and soft can make the suspension move, flex and turn the wheel slightly as if you were steering one wheel. Check these are okay. It is known for pulling under braking. Polybushes are good here!
