1 - 11 of 11 Posts
So I was out in the ZS on Friday, and i may have been a little too enthusiatic going along some of the back roads near where i live :O :p
I took a corner a bit fast, and ended up kicking the back end too far out. Cue a damn impressive slalom-skid-to-180-turn in a road no wider than the length of the car...
Somehow I managed to put not a single scratch on it (although left a lot of rubber on the tarmac), and drove away fine a few seconds later after a quick 'kick of the tyres'.
Today when i drove to work though (first time in the car since it happened), everything felt... different... but i couldn't for the life of me say in what way.
Can anyone suggest if i may have damaged the car somehow, or even suggest things to have a check-over after puting the car under strain that it ain't exactly used to?
Cheers.
hmmm i would be surprised if you had not done some damage. First thing i would do is get the wheel alignment front and back checked, then look at suspension for any obvious damaged/bent components. Most likely you will just have thrown alignment out and bent tracking arms.
You may find it's all psychological, there might not be anything really wrong but it's just playing on your mind and you think something isn't right. I know this is what happened to me a while back! :O
yep same here, it like when i havent driven for 3 weeks once i was really twichy getting back in to the car. And after i go for a fast drive i find myself really having to stop and say dont be an idiot drive normally, next time i get in the car.
mg_zs
It good to get frights like this (ones that don't cause damage or injury that is!) - It kinda wakes you up and tells you to cop on! :)
Discussion Starter #6
Yeah it was a bit of a slap-in-the-face. At least i KNOW what the car's limits are now, before i was just guessing, and getting cocky... :(
I once turned a very sharp corner at high speed, since my wheels are quite wide, I didn't lose grip, but my tracking went all wrong, I had to keep the steering wheel turned at an angle to have the car go straight :)
Sorry for the late reply :p
What do you mean 'flat spotted'?
He means after your 180 spin, the tyres will have lost tread on the bottom but nowhere else, thus creating a 'flat spot'. Every time the wheel goes round, the flat spot will create a vibration, its possible.
1 - 11 of 11 Posts
