More gearbox problems
Following my earlier posts about rebuilding my gearbox, I refitted to the car and all seemed well last weekend.
However, I noticed a little oil on the drive again and had a look earlier. My diff seals are dry, but im loosing oil from around the selector rod that joints the gear lever rod.
I changed the seal during the rebuild and the little rubber boot. (I guess it keeps dirt away from the seal)
I used a measured 2.2 litres of oil into an absolutely clean and dry casing.
Anyone had this problem before?? It only happens when the seal is at its lowest point. [I parked the car on the flat part of my drive and there was 1 drip on the floor in the morning].
For those who haven.t seen my on going posts, gearbox is a PG1 unit.
Do you think I should refit the seal and use a bit of hylomar after cleaning??
Any advice would be brilliant, Im planning to have a go on Sunday.
