1 - 20 of 71 Posts
mg_express
ok, so nobody seems to know which fuses are where, so i thought i'd start a proper listing of the fuses and their locations.
fusebox for a post '03 mk1 ZR (may be the same as the 25 and facelift 25/ZR/streetwise) as according to handbook RCL 0546
FUSE NUMBER --- rating (amps) --- circuit protected
1 ---------------- 20A -------------- horn, rear fog lights
2 ---------------- 20A -------------- window - RH rear
3 ---------------- 10A -------------- cigar lighter/accessory socket
4 ---------------- 20A -------------- window - LH rear
5 ---------------- 10A -------------- interior and luggage compartment lights, audio unit, clock
6 ---------------- 20A -------------- window - LH front
7 ---------------- 20A -------------- window - RH front
8 ---------------- 30A -------------- sunroof
9 ---------------- 20A -------------- headlight washers
10 --------------- 10A -------------- headlight RH main beam
11 --------------- 10A -------------- daylight running lights, interior illumination (Scandinavia)
12 --------------- 10A -------------- headlight LH main beam
13 --------------- 10A -------------- LH side and tail lights, LH headlight levelling, glovebox light, clock, interior lights
14 --------------- 10A -------------- headlight RH dipped beam
15 --------------- 10A -------------- RH side and tail lights, RH headlight levelling, number plate light
16 --------------- 10A -------------- headlight LH dipped beam
17 --------------- 20A -------------- blower motor
18 --------------- 20A -------------- seat heaters
19 --------------- 10A -------------- audio system
20 --------------- 10A -------------- engine starting
21 --------------- 15A -------------- front windscreen wipers
22 --------------- 10A -------------- door mirrors
23 --------------- 10A -------------- ABS
24 --------------- 10A -------------- brake lights, reversing lights
25 --------------- 10A -------------- SCU, clock, instrument pack, engine management
26 --------------- 15A -------------- rear screen wiper, heated washer jets, A/C illumination, seat heaters, daylight running lights (where fitted)
27 --------------- 5A --------------- SRS airbag advised not to remove
please feel free to add the layouts to any other fuseboxes used in the 200/25/ZR/streetwise
Rover 200 Series Owners Manual (RCL 0245ENG - 2nd Edition):
Main Fuse Box:
Fuse No ----- Rating (amps) ----- Operation
1. ---------------- 10A ----------- Indicators, Instruments.
2. ---------------- 10A ----------- Anti-lock Brakes.
3. ---------------- 10A ----------- Clock, Radio, Interior Light.
4. ---------------- 15A ----------- Headlight - Right, Main.
5. ---------------- 15A ----------- Headlight - Left, Main.
6. ---------------- 30A ----------- Sunroof.
7. ---------------- 5A ------------ Airbag SRS.
8. ---------------- 10A ----------- Tail Lights - Left, Headlight Height - Left.
9. ---------------- 10A ----------- Rear Fog Guard Lights.
10. --------------- 10A ----------- Headlight - Left, Dipped.
11. --------------- 10A ----------- Headlight - Right, Dipped.
12. --------------- 15A ----------- Tail Light - Right, Headlight Height - Right.
13. --------------- 15A ----------- Wash/Wipe - Front.
14. --------------- 10A ----------- Engine Managment.
15. --------------- 15A ----------- Cooling Fan, Wash/Wipe - Rear.
16. --------------- 10A ----------- Reverse, Stop Lights.
17. --------------- 10A ----------- Radio, Clock.
18. --------------- 10A ----------- Door Mirrors, Air Blowers.
19. --------------- 10A ----------- Cooling Fan, Front Fog Lights.
20. --------------- 10A ----------- Engine.
21. --------------- 20A ----------- Window - Driver.
22. --------------- 20A ----------- Window - Passenger.
23. --------------- 25A ----------- Rear Demister.
Engine Compartment Fuses:
1. ---------------- 15A ----------- Central Door Locking.
2. ---------------- 15A ----------- Hazarrd Warning Lights.
3. ---------------- 15A ----------- Horn.
4. ---------------- 25A ----------- Cooling Fan.
5. ---------------- 15A ----------- Engine Managment System.
6. ---------------- 20A ----------- Air Conditioning.
7. ---------------- 20A ----------- Heater Blower.
Hope this helps.
mg_express
Discussion Starter #5
Nice idea matrix!
cheers timmy, seemed like a logical thing to do. :D
engine bay fusebox, MG ZR handbook RCL 0546
Fuse number---rating(amps)---circuit protected
1---------------10A-------------engine management system, automatic transmission selector, speedometer
2---------------20A------------engine management system, fuel pump
3---------------10A------------engine management system, glow plug relay
4---------------10A------------air conditioning relay, cooling fan relay
5---------------25A------------anti-theft alarm, central door locking
6---------------15A------------front fog lights
7---------------15A------------hazard warning lights, indicators
8---------------15A------------engine management system
9---------------10A------------air conditioning
10--------------20A------------fuel pump
fusebox for a post '04 mk2 ZR as according to handbook RCL 0596 - can confirm it is same as what Matrix Mg posted above which is:
6 ---------------- 20A -------------- window - LH (passenger) front
7 ---------------- 20A -------------- window - RH (driver) front
Where can I get hold of a 25amp and a 15amp fuse?
Rear demister and rear wiper shorted out on each other and both fuses went BANG!
rover_200_95_99
Immobiliser?
Hey all,
I have an R Reg rover 214 and our one immobiliser key has stopped speaking to the car. We've done everything possible to try and find fault with the key fob but with no joy and found on another thread that the fault can also be with the fuse. Anyone know which one I should be replacing? I checked through the lists people have posted and couldn't see anything to do with it. Am I just missing something obvious?
Thanks for your help,
Paul
Hey all,
Paul
Do you have central locking?
If you do, does it still work with the key in the drivers door lock?
Dave
mg_zr
Hi and help please!
Hi all i'm new to forums so please be gentle lol!
I have a problem with my little zr she's not very well lol
She's a zr vvc 160 2002 plate and she won't start. she will turn over but refuses to start, i've changed plugs,leads and coil packs i've took both camshaft and crankshaft sensors out and cleaned them but still no joy. The fuel pump doesn't make the usual hum when turning the ignition on so it's not priming I was gonna check relays ect but what's what's in the fuse box under the engine which one is for the fuel pump or fuel cut off etc I'd rather check this before chasnging the fuel pump.
Any help would be appreciated
mg_express
Discussion Starter #20
the cut-off switch is a round black button in the engine bay near the windscreen, there's a switch behind it to tell the car when the bonnet is closed.
do you have a round or square alarm fob?
as random as it seems as a question, the layout is different between the 2 systems used.
1 - 20 of 71 Posts
