1 - 1 of 1 Posts
cityrover
More great items brought to you by:
THE MOFF SHOP / TMS MOTORSPORT]
FS: Land Rover Defender Discovery 30mm Wheel Spacers - 5 x 165 M14 x 1.5 124mm Forged AL6061-T6
To give your car that perfect visual and performance touch, the engineers at Direnza have created a complete line of wheel spacers. These are designed to give your vehicle a wider, more stable stance quickly and easily. With the correct Direnza spacers installed, your car will take on a more aggressive look with wheels and tyres filling the wheel arch exactly the way they should.
Fine-tuning your track width doesn't just enhance your car's look, it also gives you improved handling, performance and optimised roll capabilities. Direnza spacers are available in a range of sizes, letting you position your tyres exactly where they will look and perform their best. All Direnza spacer kits come complete with all necessary mounting hardware.
The Direnza wheel spacer is one of the easiest and most cost effective bolt-on performance handling enhancements for your vehicle.
Manufactured from high strength lightweight 6061-T6 aircraft aluminium alloy, forged hard anodized for durability and corrosion protection.
Precision engineered hub-centric and model specific for a perfect fit and wheel balance.
Limited life range tested for wheel bolts/studs (1 million times) in accordance to ISO3800.
Strength tested for applications (bolt/stud/nut) in accordance to IS0898-6, SAEJ429, SAEJ995.
Anti-rust tested (NSS 72 hours) for applications (bolt/stud/nut) in accordance to IS09227.
Improves wheel and tyre spacing within the wheel arch.
Better handling.
Increased safety by widening the vehicle track width.
Fix brake caliper to wheel clearance issues - particularly when fitting big brake kits.
Adds inner arch and suspension clearance.
100% genuine Direnza product.
Fitting instructions included.
Brand new in the box.
Fits:
Land Rover Defender (91 - onwards)
Land Rover Discovery (91 - 98)
Land Rover Range Rover (70 - 94)
Before purchasing any wheel spacers please measure the gap between the outer edge of the tyre and the wheel arch. Take 5mm from this figure to help give the maximum thickness wheel spacer suitable for your vehicle. It is good practice to work to 5cm less than this figure to allow for movement in the vehicle suspension. When measuring your wheel gap always measure both the driver and passenger sides on the same axle as measurments may differ slightly and you should always work off the smaller of the two figures. This is especially important as spacers which have been fitted and / or tested cannot be returned.
Below you will find a brief glossary of terms you may encounter when checking the suitability of wheel spacers for your vehicle.
Price: £91.66
Price (inc. VAT): £109.99
Please see the website for more photos and details...
Email us: [email protected]
OVER 10 years experience
We ship worldwide
1 - 1 of 1 Posts
