1 - 12 of 12 Posts
Hello all i have noticed on my rover 214 bubble shape on the intermitant speed they stick both sides on the window on the other two speeds they work fine any clues i have sprayed some WD40 in where the wipers are but still doing it cheers for all help scott.
yeah i have a wierd problem too. On internediate, the front and back wipers sorta go halfway, stall for 5 seconds, then come back down. Works fine on the other 2 speeds though?
i not sure how old as bought car in january seems to be a problem with all rovers i thought rovers were better than other makes just proves that they are not with there silly breakages.
Sounds like a motor change mate, unless you fancy stripping it down cleaning and re greasing the internals.
Lates
I have this - it's only on the drivers side tho and also 1/2 way up the screen, everyother time its ok??
it normally does it on intermitant but when there aint a hell of a lot of water on screen? Any suggestions??
1 - 12 of 12 Posts
