· Registered
This is a project that I keep starting but never get around to finishing :confused:.
Some time ago, I fitted the on/off switch and I think I fitted the relay. But connecting a meter to the feed cable behind the bumper shows there's no voltage there (checked with key in ignition position, headlights on and the front fog switch shows a green light lit). I cannot find my notes of the work I did previously. Can anyone tell me where the relay needed installing?
Other than the switch and the relay, I don't recall any other changes being needed. I don't recall an addition fuse needs installing.
Bazz
· Rover Lifestyle
Rover 200 Rover 600
I imagine you did not look up for relay locations I created for this purpose some time ago: Rover 600: Relays and ECUs
There you have some pictures of the place where the relay goes.
Here you have fuse list: Rover 600 fuse listings
Both of these threads are amomg stickies.
Among the fuses in the engine compartment fusebox I see fuse nunber 33 rating 15 Amps which serves front fogs solely, so I imagine you need to add it as well.
· Registered
Many thanks for those comments. When I kicked off with this, I looked through the old posts on the forum and I thought I had copied all the useful info into a Word file, but I cannot now find any such a file. There are some occasions when I just feel I am getting seriously old...and this is one of them!
B
· Registered
Fuse 33 is the answer. I have a fuse list on file, which I thought was the one you created a long time ago, but seems not so, as it only shows fuse numbers up to #22 in the engine bay and that's what has misled me. I'll update using the links you posted. Many thanks for your help.
