1 - 10 of 10 Posts
You can make them flash, if you are an electrical kinda guy. Someone on here did work on doing it himself, but he didnt get it fully working.
In a simple anwer, you cant get them to flash.
It was around R plate, give or take the odd few.
Mine dont:(
LOL yeh...these negatives we turn into positives...For example..quite related...
The doofer only works a few metres away....
This is a security feature, as if you open it from far away, someone could steal something from it.
Yeah right!
rover_45
There is no way to make the indicators flash on the older alarm unit. The difference is the later ones have two connectors a white and a grey one. Your one will only have the grey one. The white one works the interior light wake up/sleep, indicators and the passive coil. The range of the fob can be extended if you take the main aerial out of the loom. On all Rovers from 94 with the standard alarm have the aerial built into the wiring loom and if you take it out and lay it straight under the dash you do get better range.
i assume that is the same for the 25.
Where abouts under the dash is the aerial? Don't really want to undo lots of loom to find it.
25tdi
1 - 10 of 10 Posts
