Will ZR springs and dampers be a straight fit on a mk3 200 or would I need/do anything else?
Not the sort of lines I was thinking along.cirian75 said:Yeah, pay someone good to do it, and get it properly tracked afterwards, see my above post
The springs and dampers are already assembled as a unit so won't need compressors or will I need them when removing the old springs and dampers.cirian75 said:the haynes manual, Spring compessor, axle stands, a few mates, mobile phone, and a first aid kit for when accindently release a compressed spring and knock your self out and few teeth![]()
I think its like this, if you are just putting new spring and dampers that are already assembled then there is no need to dismantle the new or old ones. Just take the old spring and dampers out and replace with the ZR ones.ashy said:For some reason my enthusiasm for this job is waning....:bored:
Can't I just knock the struts and springs out once the bolts are undone?
Mike thanks for the info. When and why will I need compressors if I'm fitting the whole lot as an assembled unit?michaelperrin said:Ashy....
Bank on about 1 hour per corner.
Ignore comments that say it takes an hour for all 4...a stuck bolt is a stuck bolt!
Few days before, wd40 all the bolts you will be undoing.....helps to loosen them a bit.
Then you just need good tool set, axel stands, or couple of good trolley jacks.
Spring compressors -about 25 quid ish, or borrow a set.
Allen keys...get the ones that fit in a socket, not the stand alone ones.
Haynes manual, and the RAVE cd is a lot better actually.
The backs are easy.
The fronts you sometimes need to be a bit strong to release them!
I would guess the 160 is uprated slightly?Striker said:BTW Is there a big difference between the ZR105 and the ZR160 suspension? EPC lists the front dampers as different parts.
Ahh right.ashy said:Mike thanks for the info. When and why will I need compressors if I'm fitting the whole lot as an assembled unit?
I really don't fancy having a spring whizz past me head head at a 100mph.
I've got the Rave CD. Loads of bangin' toons on it...no seriously I've got it...![]()
michaelperrin said:Ahh right.
If you have the whole assembled unit its miles easier. You getting it second hand already assembled? Easssy
Normally when people replace springs, you take out the whole unit from the car, then to remove the spring from the cups, you put spring compressors on, usually about 3, spread out, and slowly tighten each one, till you can remove it. WARNING!....Make sure this is secure, two people!
If yours is all in one you want need too.
You prob know all that, but useful for others.
Erm yeah, dont leave things on the floor and have lunch and forget which way round they went like i did!ashy said:Good I was hoping I wouldn't need the dreaded spring compressors. So it should be just a case of whipping the nuts and bolts off and knocking the struts out then.
Any tips best way to do it and easiest way to put then new units in?
Thanks Mike.
Why's that Mike? Do you think it might get damaged or get in the way?michaelperrin said:EDIT...oh yeah...you got the front bib on aint you? Remove it before you start work![]()
stumpy said:If its anything like my 216 underneath you'll need spring compressors to remove the old ones AND install the new. And I hope you have more luck than me with the bottom strutt bolts!
Its true, done mine today and you don't need the spring compressors to remove the struts.cjmillsnun said:If you are replacing complete units (ie damper and spring) and they are already assembled, you do NOT require spring compressors.
How long did it take you Ry?Ry said:Its true, done mine today and you don't need the spring compressors to remove the struts.
To get the strut out, about 30 mins per wheel, maybe a bit less for the rear as they are easier. Then about 20 mins to refit each one. It took me about another 20 mins to dismantle each sping, but you wont be doing that.ashy said:How long did it take you Ry?
