rover_75
I guess my question is not just related to the 75.
I was driving home last night and the hand brake warning light came up several times; I checked several times to see if it was on, ever so slightly but it wasn't.
Is this something I should worry about?
I do think it's something I should get looked at?
I should be grateful for views.
Thanks in advance.
Martin.
rover_75
You would need to check 2 things: handbrake light switch and level of brake fluid in your brake system. Both of them will trigger handbrake light.
Thank you very much. I am not going to play around as it could be dangerous and will contact the garage I use and get them to check it out straight away.
rover_75
Just an update. I booked my car in to get the issue checked out. The garage couldn't find a fault. The brake fluid was fine. I will have to monitor the situation and if it happens again I will look into purchasing the handbrake light switch and having it replaced and hope that may solve the issue out.
