21 - 36 of 36 Posts
MG TF 135 2003
Discussion Starter · #21 · (Edited)
After one week of waiting for Rimmer answer (they said 2-3 working days) this is their nonsense supplier answer:
The tanks are no longer produced by the OEM so we have a kitting operation that adds the inserts in a poly bag for the dealer / customer to fit.
The moulder of the tanks – provides the tank with any internal floats fitted, but they cannot add the inserts.
So for many years we have serviced the metal inserts in a poly bag.
We did for a short while try to fit them but this is a labour intensive operation based on the volume we produce and some inserts could fall out whilst in transit or storage.
Edit:
this is not a Rimmer answer, this is a Rimmer's supplier answer.
Rimmer said they will insist on looking for an answer.
MG TF 135 2003
Discussion Starter · #23 ·
Seems this is the final answer from Rimmer:
Thank you for your email.
Our supplier have recommended slightly distorting the inserts by tapping them on the outside, this will allow them to provide an interference fit into the tank.
I think I have to tap a lot and distort a lot this insert to create interference. Judge by yourselves.
Sleeve Collar Button Cleanliness Metal
That aluminium insert looks like stainless to me but it's not in front of me, the whole thing looks to be a complete bodge and therefore not of merchantable quality. Tell Rimmers that you want a full refund and that they should cover any return costs that you may pay. Or maybe their mechanics could fix it when its returned. Afterall, they make enough profit out of us. Regards and good luck. D4KGP.
1995 MGF Mpi
Yeah, that insert is completely the wrong size. I agree with D4KGP that Rimmer shoulfd provide a refund, or at the least, send you another one at no cost. Have you sent that picture to Rimmer?
I took a look at my F's original expansion tanks, which was replaced when I installed a B&G low coolant alarm, and the original does not have metal inserts at the hose connections.
There is noway a tap on that insert will allow that to fit, it's not just a slack fit it's a complete joke and to be trying to pass that off as suitable is appalling. It's just not fit for purpose and the supplier should either offer you a full refund or a suitable replacement, at their cost. You bought that in good faith and ended up with a pig's ear of an item. Don't let them get away with supplying inadequate parts, they have supplied it and so It's for them to get on to the supplier to sort out, not leaving you in the lurch.
MG TF 135 2003
Discussion Starter · #27 ·
Yeah, that insert is completely the wrong size. I agree with D4KGP that Rimmer provide a refund, or at the least, send you another one at no cost. Have you sent that picture to Rimmer?
I took a look at my F's original expansion tanks, which was replaced when I installed a B&G low coolant alarm, and it does not have metal inserts at the hose connections.
Yes, I sent all the pictures to Rimmer.
Install it without the metal insertions is also an option... but I don't know if in the future the plastic will break because of fatigue. I think if those inserts are there will be for some reason. How much time or km has your new tank fitted without inserts?
I guess is aluminum because is not magnetic.
Thanks to all for your thoughts, I'll keep you posted if finally I get a solution from Rimmer.
It depends on the grade of stainless, 304 & 316 are non magnetic grades. D4KGP.
2002 MG TF VE51FTF
Below is a copy of the email I sent to Rimmers on the 28/10 their response is a deafening silence, which I think shows their complete indifference to customer concerns. They are now definitely on my list of suppliers of last resort only, the picture that pixsa posted beggars belief that anyone thought that was fit for purpose.
Hi,
I don't know if you are aware (if not why) but there is a thread on the MG-Rover org forum about your replacement for the TF expansion tank which following the thread appears unfit for purpose. This does appear to reflect badly on your company as does your apparent indifference to your customers concerns, being a new TF owner myself it will certainly make me think twice.
Regards
Peter
  • Haha
Reactions: pisxa
I can understand the good intentions to get to the bottom of this, but due to delays, shipping etc. etc. why not get a local machine shop/ technical college to turn you up a suitable fitting piece of stainless pipe?
Kind regards,
Austin.
I know you can buy thin walled stainless pipe. I don't know what o/d size you're looking for, but I'm sure you could get something closer to what you currently have. Whilst I appreciate the frustration and the poor service you have received, it isn't helping you get back on the road. I'm sure a local jobbing workshop would knock a suitable substitute, or even try a garage. However, after alls said and done, this might never get resolved as quickly or to your satisfaction with Rimmers.
Which still leaves you out on a limb and still needing to get the tank fitted.
1995 MGF Mpi
The original tank that was fitted to the car, which did not have Al inserts, was fitted for 15 yrs and ~85,000 miles. The replacement, which was part of B&G's coolant alarm kit, did have the Al inserts.
Austin's suggestion of fitting your own inserts is an excellent one, or just fit the tank since you are not getting anywhere with Rimmer, which is really odd in my experience, I've found their response to issue to be excellent in my experience.
This is worth reading regarding the VW expansion tank,
Coolant Hose Split And Burst - Page 2 - The MGF Register Forums
The download is on the second page and gives you all the you need including the mounting bracket
Although not fitted yet I am going to try this low level warning sensor;
and will add a buzzer to the flashing LED and one of these delay timers so the alarm will not go off when cornering or braking.
Total cost of a 2012 VW Passat expansion tank, low level sensor, buzzer and delay timer including postage is £20.52
I forgot to say that the VW Passat expansion tank was a used one from ebay, it came with the plug and short lengths of wire. It is easy enough to join the white wires to the ones that came on the tank. There is some info that it is better to buy used than new aftermarket ones, especially the caps.You need a blue cap not black
21 - 36 of 36 Posts
