If you can do that then you should have been a gynecologist. I'm not saying it's impossible (although it might be), but I would always drop the subframe if the engine was to come out. It would prove so much easier in the end.Chaps, I'm a total newbie and I'm forced into removing the engine because of a CAM BELT failure.
I've taken the HEAD off and can see broken valves and in the block I can see broken piston shell after removing the sleeve on cylinder 3.
I've never re-built bottom or top end of an engine and without any detailed instructions would not fancy taking it on. So my options are replace engine with secondhand or recon.
Question is, as I only want to replace the engine, and bearing in mind the head has been removed, would it be easier to take the existing engine through the top and put the replacement through the top or should I raise the car and then drop the engine??
Please let me know your thoughts
