So today I changed the oil and filter, but when emptying out the old batch only 3 litres came out instead of the expected 4.5L..
Before you judge me - I check once every couple of months and intermittently when I'm doing fluid/air checks for a long drive, and have always used the dipstick as an indicator. The car sounded tappet-y the last month or so but as I thought the oil was at the correct level I just put it down to needing an oil change. Now the oil is filled to 4.5L the tappet sound has stopped, but my faith in the dip stick has been shook.
Has anyone else found the dipstick to be misleading, and although it's just a dipstick check, is there anything I could be doing wrong or tricks/quirks I don't know about the MGFs funky dipstick positioning?
On a side note I also cleaned the Idle Air Control Valve (IACV) so I'm hoping the rev-hunting will stop - tomorrow will tell. Fiddly thing to get out, though!
