1 - 5 of 5 Posts
Hello, got a quick question, if my orange engine fault light flashes once and goes out, does this mean that it has stored a "fault code"?
Any help much appreciated!!!!!!
Regards
Stu C
Regards
Stu C
When does it flash - when you are driving or when you first turn on the ignition?
Is it petrol or diesel?
Is the car going ok?
Even if a fault code is stored, it will eventually be cleared if the fault doesn't persist.
Hi Ron, yeah definatly diesel ;) It happened when i was driving, although yesterday i changed the EGR modulator valve and the manifold absoloute pressure sensor and seems to be ok so far, so that might have done the trick, apart from a squeak at 2500 revs when driving, but i think thats just tightening something up.
Major Ingram said:
Yup, there will be a stored trouble code, but if it's running OK, just drive on Stu!
hehe, am doing Major :D it happened and shes being driving normal now, but seems to be fine after them bits i replaced like.
Ah well, keep chugging through the universe i suppose :bgrin2:
Cheers for the help though! much appreciated ;)
Regards
Stu C
1 - 5 of 5 Posts
