rover_45
Set off to drive from Bournemouth to Wembley today to watch the Cup Final and got about 12 miles when the Engine light came on.
I didn't want to risk it so came back and we switched to my brothers car.
I checked the oil, coolant etc before I set off and all is good.
I have not noticed anything unusual - no noises, no vibrations, no loss of power, no overheating.
Had a quick look under the bonnet and cannot see anything odd.
Is there anything obvious I can check?
Any common issues?
Do I need to take this to a Rover specialist to be hooked up to a diagnostic machine or will any garage be able to diagnose or the AA for that matter?
Cheers,
Dubs
I know when my engine light comes on it's always emissions related.
I would get it hooked up to a code reader as soon as you can.
rover_45
Are the code readers generic or Rover specific?
Will any garage be equipped to read it or do I need a Rover specialist?
rover_45
Good news,
A local garage I trust has a machine to read it so will get it looked at tomorrow.
Hope its nothing too bad (read as Expensive).
if your any good on a pc you could save money by buying an OBDII (OBD2) lead and plugging it into your car yourself, that will set you back just over £20 if you search ebay for "elm 327 scan tool" that might save you a bit of dosh! i bought one and im just getting to grips with it, surprisingly it told me a fault that i didnt even notice and soon rectified =D
rover_45
Took it garage...they had a handheld diagnostic device.
It came up saying the engine had a misfire.
It has misfired occasionally for a little while now so not sure why it threw up an engine light this time.
Anyway have it booked into change the leads and plugs which I was going to get done anyway to try and fix the misfire.
No charge from garage for checking what the problem is so not too bad overall.
