I've posted about this previously guys but wasn't able to explain what the issue really was so I recorded it...
The night one is just idling and sometimes the variation between the revving and the drop off is greater.
http://www.youtube.com/watch?v=G71fmdvhumI
The day one is a good representation of how the revs can stick at times.
http://www.youtube.com/watch?v=H0CNGgkL17I
Initially I thought it might have something to do with the headgasket being on it's way out. This has since been fixed and as you can see i'm still having trouble with it.
I've tried the throttle reset (key to pos II, full throttle 5 times etc) the engine just seems to stall upon restart after doing that instead of doing anything else.
Anyone had this problem and fixed it?
Edit:
This is not a constant problem, it also occurs randomly. Engine temperature isn't a factor. It can be ok in the morning when cold but play up when I pull on the drive in the evening and vice versa. It is, to say the least, mildly irritating.
Edit:
