I had a problem similar to this about 18 months ago, which turned out to be an ECU fault due to the battery running down and jump starting it too much, but this time the car has been in constant use, and the battery and ECU have not been disconnected at all.
The problem started about 2 months ago, where sometimes the car would start but then immediately cut out, usually restarting in afew tries.
However it has got progressively worse and I actually had to get my car towed the other day.
When I unlocked the car the immobilizer light turns off, but when I turn the key the engine fires but no matter how hard I try by putting my foot on the gas the engine just cuts out.
If I try again it will just turn over but not fire, meaning I have to lock and unlock the car before it will even fire again.
The temperature gauge has also been acting strange, sometimes when I turn the key to position 2, the gauge shoots right up to the top for about a second and then drops back down.
Any help will be much appreciated, otherwise i'm going to have to get rid of the beast and pick up another little run around
Cheers, Jon
Cheers, Jon
