Hi,
I am having an attack of the gremlins and was wondering if anybody could help.
The symptoms:
a) 3 times in the last week, when I have turned the engine off the display containing mileage, mode of drive (it's an Auto) external temperature ect has remained on, - Nothing turns it off.
b) The IPK (Computer display) misbehaves, usually on starting it works perfectly, the display for example an open door then drifts to the right or left, the words fairly unreadable, - occasionaly I just get a dim red line across the thing or it doesnt work at all. - However on the next trip it starts as it should. Once when driving it flashed on wth the red line.
c) There is an intermittant but regular static beat on all channels on the radio, for some miles it seems OK, then it starts over, - occasionaly there is a squeak when turning it off or on.
d) 3 times I have disconnected the battery for 10 mins or so, everything returns to normal - but only for a while.
e) My plenums are bone dry and have been for a long time - I even found a spider had made a home in there.
f) In all other respects everything else seems fine - all toys work.
Could it be that the battery is on the way out? - The car starts and runs perfectly, on another vehicle I owned battery problems caused issues with the ABS, - I wouldnt have known.
I would appreciate the advice of the forum members as to what to do, I dont want to go replacing parts one by one until everything is resolved.
The symptoms:
