· Registered
cityrover
I have a problem with electrical driver window when the door is closed, switch doesn't work, but if a open the door switch works well, anybody knows this problem, is it any relation between the door opening switch with the window opening switch, where i should look to find the problem.
Car is a Rover 420 sdi from 1997.
Thanks in advance.
· Rover Lifestyle
Rover 200 Rover 600
Door opening switch and window opening switch are in no correlation.
This is not known problem in sense it happenes frequently.
To me thismlooks like you loose some contact when you close the door. So you will need to remove door card and trace the wires and check them good, espexialy when wires pass from door to body as that is the place where this break could happen.
· Registered
cityrover
Well, i was out of forum for a while, i had the problem of the window till yesterday i used an electrical contact cleaner outside the window switch and miraculously switch is working good.
Sometimes less is more. I am getting lazy with the car, doing very little sometimes.
Cheers and beers.
