1 - 2 of 2 Posts
hi i own an MG TF and the drivers window takes about 20 tries to close properly and i have to push the glass and try to get it to go all the way up . the off-side window has somehow come off the runners and drops as soon as i release it. is there any way i can fix it and if not where can i take it to be fixed? i live in london SE19 and have you any idea of how much it will cost gulp thanks
Hi not sure with this model but i do know you will have to take the he door card off, and inspect the window mechnisims and lubrucate the rails and motor. You may well find out that the motors arms are bent if the window is not moving it is either lack of pwoer, or the window is jammed.
if one is broken normally you could take the other door card of to see how it is fixed etc and use it as a guide to refit and new one.
1 - 2 of 2 Posts
