1 - 5 of 5 Posts
Please help, i inherited a 96 rover 100 111i great little car until head gasket went,fixed that then it started intermittantly missing so i took it to the garage and they said it brought up a fault code of throttle pos switch, but they said it was prob the ecu, so i brought an ecu of ebay {as i,m rapidly getting skint} thinking they would swap straight over [obviously not] is there any cheats to match it to my car or have i got to get fleeced some more
:taz: ps im pretty sure its a fuel/air prob not ignition miss, pps if anyone has got any other ideas please let me know as the garage were not 100% on the ecu diagnosis
the ECUs are matched to the immobiliser ECU so it shouldnt even preasurise the plenum chamber. surpossedly you can switch ecus which have the same letters on.
Might be worth getting a new throttle position sensor first. It is on the throttle body / opposite to where the accelerator cable attaches. Only a ten minute job - and it might fix the problem.
After it has been fitted, you will probably need to do a reset - turn key to II, press throttle to floor 5 times, then start the car.
Failing that I'd look at the electics (leads, plugs distributor cap and rotor arm), and other sensors (CPS - Crank position sensor and temp sensor) before condeming the ECU.
If you don't understand what I've sed above, do a few searches on this site :)
Good luck. PS. If you are in cheshire, I will have a look!
Thanks for your replys guys, i think il prob try the throttle pos sensor as it does feel like a fuel/air prob and if you accelarate gently it seems ok, so the missing/hesitation might be unburnt fuel [and its prob the next cheapest thing to replace]
1 - 5 of 5 Posts
