I have a converted Rover 214 to a 1.8, I've still kept the 1.4 ECU with the MAP system disconnected to make it over fuel, I want to correct this as now it is pinking, I've been looking at new ECU's and have found converting it to MEMS 3 is too much work as it means changing looms and ignition and rocker cover etc, I'll get round to it but not yet.
Now down to my question, I need a 1.8 ECU which has the MAP sensor in the ECU, I've been shopping around and was wondering if the MGF 1.8 ECU would work (obviously using 5as) or would a land rover Freelander pre 99 ECU work and run it better than the 1.4 ECU.
Any help with my struggle is much appreciated, thank you very much!
Regards Ellis
P.S I will be installing the 1.8 flywheel
Regards Ellis
