Ebay service kits opinions welcomed
870 Views 4 Replies 5 Participants Last post by  hollinshead
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150392600278&ssPageName=STRK:MEWAX:IThttp://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160382074102&ssPageName=STRK:MEWAX:IT
I would welcome opinions from people more knowledge than me (shouldnt be to hard to find) on the quality and value of the above while I realise that some of the items are not going to be of the very best quality ie plug leads from what I can gather magnecor are the best but not cheap also plugs are probably the same ok but not the best will there be a marked difference in the running of the car in using the very best components or is the benefit more in increased durability :)
1 - 5 of 5 Posts
as long as you give the full details of your TF (the HT leads vary from F VVC to TF VVC) I can't see anything wrong with that kit.....apart from it seems very pricey.
Probably cheaper to go to a motor factors and buy the parts separately. Plug leads aren't really necessary for a service unless yours are giving bother the rest of the parts are of good quality though.
Last year I bought a service kit from eBay without the oil as that tends to make the P&P expensive, I would also only buy a kit if the parts are OEM at less then could be bought at my local Xpart Centre otherwise as said you may as well buy from a local motor factor.
I bought a genuine MG Rover service kit from an xpart dealer on ebay.
It had the air filter, new plugs, oil filter and sump washer.
Then I just bought some nice oil from halfrauds.
I got mine from here:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250682158274
Which is the same as this part on Rimmers, only cheaper:
http://www.rimmerbros.co.uk/Item--i-ZUA0000TF
Although I'm not sure if the airbox on a trophy is the same size as a TF, or if it's different?
1 - 5 of 5 Posts
