OK, just wondering where the screw is on the "right" of the drivers door trim, I took the handle off and the "material" insert bit but nothing under there, quite a git to get it back on as well.
It keeps slighty rattling as I drive, and its getting annoying now, I think it could do with a tighten up.
Well when you open the Door you can see the left screw as you obviousy know, Tightened that as much as a could, but nothing on the right side, unless its a slot in type.
can't remember that well to be honest. i try not to mess around with mine too much cos it's been to the dealer 4 times for a rattle in the door and it's still not sorted.
is there a trim around the door pin??? if not this bit rattles.
it's possible that it could be the central locking rod rattling against the metal or glass......they can work loose sumtimes.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
MG-Rover.org Forums
