hi
after a little help,got a L reg 216 ,if i start the engine and drive half a mile turn off the car will not start again ,i have changed the ignited module in the distributor,this has not cured it the reason i done this is it is loosing spark at the plugs i have also found out that it is loosing power on crank to the coil ,wait ten mins and it will start ,there are no blink codes logged.......
any ideas ????
relay
i had this problem and solved it as follows....
locate the brown relay under the centre console......
remove the relay and take the cover off.
run a soldering iron over every solder joint, this in effect solders all the component parts again.
re fit and try
mine has been fine ever since.
it seems that the solder joints go 'dry' when hot.
this is expained elsewhere on these forums
let us know how you get on
good
glad i could help, although i should not take credit for it as i solved the problem on mine with a thread off here.
But it does not hurt to bring it too the 'fore' again for other newbys like me!!!
