i have a mk3 200 1.6 petrol - my sister works at a motor factors and has got me a battery from a 2.0litre diesel 200 - she says its taller than mine....
will it fit?
other_rover
They are not usually taller, just wider. If you have space around the battery tray then yes it should fit. If the battery is designed for the mk3 200 diesel there should be no issues, and there should be another bolt in the tray so you can bolt the battery down.
