Hi all !
I recently decated my Ti and deleted the small silencer. I also added a Forge blowoff valve. However, i noticed small coughing and spitting from the exhaust. The engine seems to run fine.
In addition to that, it smells petrol from the back and consumes a lot of fuel. So i suspect it's running too rich. I read that the ECU has to adapt because of the cat deletion so it runs rich to protect the engine.
Finally, there is a boost cut. If i go full throttle from 2nd, 3rd, it is fine (it feels heastating a bit like not a nice pull, you can feel the turbo hesitating on boost but nearly perceptible) . And when it comes to the 4th there is a boost cut around 4000rpm.
Can you help me ?
Can you help me ?
