No, but I have minnions who canOrion said:I think you should do it.
The gains will be minimal but there's nothing so worthwhile than a cheap or free mod that you did yourself.
You can weld, can't you?![]()
LOL.. Galway roads are WORSE. TBH I should be driving a land rover. I've removed those naff Ultra lexus lights and replaced them with ABC ones... look much better.Orion said:Finally got a look at your website, alt. Got a couple of comments, if I may.
Right, where do I start? Oh right - lower it. Lower it. Lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it, lower it.
Well, unless the roads in Galway are as bad as they were in Donegal last time I was there. In which case, why are you not driving an M1A1 Abrams?
I won't comment on the styling cues - they're yours alone. It's nice and pretty though. Good work, fella.
LOL nah wouldnt be that bothered, nor can I afford. Might go for a de-cat in the future. In the meantime im going to sewttle with a Magnex 6x4 oval backboxOrion said:Gah. The Ultras are made better than the ABC ones. Each to their own of course, sir!
As for the rest, I believe you grind off as much as you can reach. No, this doesn't help lower down in the pipe but I think that the biggest "intrusion" is at the ends anyway, because of the way that welding works and because of the nature of the piece.
If you're Really That Bothered(tm) I do know that Janspeed do a stainless, mandrel-bent manifold. But I have mailed them about it a couple of times including my mortgage details and credit limit and they have not responded.
