Cruise Control
1 reading
745 views 1 reply 2 participants last post by  jadorff
Hi All,
The handbook for the HS explains the basic cruise control and the adaptive cruise control. The instructions being the same apart from twisting the stalk to set the adaptive distance in the later mode. What the book fails to mention is how to switch between the two options. My HS is just defaulting to the adaptive option and no amount of twiddling lets me turn the adaptive off. Does anyone know of a way of switching between normal and adaptive cruise? Cheers.
I dont believe on cruse control you can switch the distance between cars off only change distance. If you put the indercaror on to pass it gives you throttle control and goes back to normal once you pass let the throttle go and it goes back to cruise control touch the brake and it torns cruis off
