Cruise control not working after a clutch change
2.2K views 6 replies 5 participants last post by  marley
That's basically it folks, had a clutch change on my 75 and since then it doesn't work, no lights, no nothing...
Any ideas?
P.s. good forums!
Any ideas?
P.s. good forums!
Most likely that the fitter has dislodged the clutch switch whilst doing the bleeding of the new cylinder(s). Feel under the dash & you'll fnd the switch, push it fully home & most likely you'll restore the CC.
Regards, Rob.
hi had the same when i had the clutch master cyl changed a few weeks ago , the switch is mounted high up on the pedal box you cant see it only feel it , when you have hold just push it back down you will hear a few clicks , then job done :chewie:
I had the same problem when I had my new clutch fitted too! Did as the above posts said and no probs since! (saying that "sometimes!" I have to put my foot under the clutch pedal-giving it a slight push up! for the cruise control to work!).
Sounds like you might have an ailing master cylinder if it is not returning the pedal to the top fully!
Regards, Rob.
