1 - 13 of 13 Posts
Long story made short.
no radio.
no clock.
no interior light.
leaky boot.
no boot light.
//edit - rear wiper too
suspect fuses, its dark and my illegal dance party CD doesn't work right on Vista - which fuses should I be looking at and where?
would boot light also be on same fuse? thats whats messing with me bonce. :dunno:
//edit - and the rear wipers U/S too.
I'm going to. got to pull the soaking carpet out at first light :mad: :roverjockey:
anyone got a can of petrol and some matches? :cus:
Discussion Starter · #8 ·
sorted.
the interior lights, clock, boot light, rear wiper and radio all run off the same 10amp fuse.
I wondered why my Clifford would go off randomly when it rained and when arming, so I counted the LED flashes and it told me that the boot was being triggered.
After doing some digging I found that the alarm uses the negative wire for the boot light as the trigger.
On closer inspection and some unravelling of loom I found this....
:shake:
The wire was just rats tailed onto the wire, no connector block, nothing. :shake:
after some trimming and cutting I dropped them into a connector block, stuck a new fuse in and hey presto, it works - with no more warnings from my alarm either!
******* cowboy installers :shake:
If the fuse number is the same as the R25, the fuse in position 3 runs the audio/clock/interior light.
I had a similar problem, checked/changed the fuses. Everything is ok now.
Skelo
Discussion Starter · #10 ·
I cant remember the number, i just thought it was strange having the rear wiper running off it too :dunno:
What i found strange, was that with the fuse blown, the clock still worked!!!
Just the fact the clock always was 5mins slow, changed the fuse and the clock/interior light and the CD changer works!!
Skelo
1 - 13 of 13 Posts
