HI I know this forum is only for rovers but I'm doing a cambelt on my mates corsa and was hoping for a bit of advice if anyone is clued up on these engines. its a 1.7 cdi 97 plate Izuzi engine and I can't suss out the timing marks for the crank. There is a mark on the crank but I can't see one on the case to line it up or find any locking hole to put a pin in the gearbox. Does any one know how to set the crank in the right place coz I'm panicing a bit now and I have it all stripped down. Thanks, Andy
You need a M6 bolt in cam wheel, M8 in injection pump wheel and there's a line in the crankshaft gear that lines up to 12 o'clock against a mark on front of engine
