Hi All i have a 05, facelift zr, 1.4, I bought it new, its all original.
Some time ago the heater stopped blowing warm. I traced this to a plastic (With saab cast on it, is it a bypass?) valve under the bonnet.
I replaced this with one from a 05 zr scrapper, as rover garage hadn't seen one before.
Anyway, this replacement one went a while ago. When the valve is good, there is a silver ball inside. when duff, this ball becomes lost inside the engine somewhere.
Now, after any short or long drive, the water in the header tank is boiling, fan always on, radiator top hose is rock hard, bottom hose is soft and freezing. (I've proven rad is clear.) The temp gauge never rises above where it always has been. I'm starting to worry i am doing damage by overheating parts of the engine.
Where might the 2 balls be? (Nothing rude here please, lol)
The oil is clean, and it uses water, probs due to the boiling up, and forcing its way out of the tanks lid.
I dumped the water system when i changed this valve thing last time, but struggled to get it to bleed fully. mite this be cos of the original ball blocking somewhere.
Any help would be great, thanks in advance.
Stu
