Coolant Level Warning Light
7K views 14 replies 5 participants last post by  JTizzle
Yet again I have the red low coolant warning light illuminated on my dashboard. I've checked the level in the header tank and it is bang on (I have a bit of tape stuck to the side of the tank so I can tell that it has dropped barely 1mm over a year)
Having had the entire cooling system replaced, including 2 head gaskets (MLS), inlet manifold, water pump, cambelt, heater matrix, etc, I am sure the system itself is OK but the sensor is dodgy.
Now, in the past the garage have told me you can't replace the sensor component by itself and must replace the whole expansion tank unit - at a (fitted) cost of about ÂŁ60!
Is this true? And does anyone know if the Rimmer Bros 'sensor-level low coolant' for the MG-F/TF (part no:pCJ000040) will fit the Rover 45?
Yes, you can replace it yourself.
The system does not have to be drained. Remove the two bolts securing the tank and pull it slightly forward and up to release it, there will be enough movement in the hoses to turn the tank so that you can see the sensor on it's underside.
It might be easier to leave the wiring connected as the plug will give you more grip when pulling the sensor out.
#14 ·
I take the point, but I'm also sick of that light coming on every time the coolant drops a mm! I think the old sensor is a bit flaky.
thecff said:
And someone had a go at me when I said 9 times out of 10 a garage will rip you off charging for work that doesnt need doing.
Exactly! That's why I didn't wanted the header tank done as well, as there's nothing wrong with it!
#15 ·
Just to wrap this up - the coolant level sensor was replaced in the end with the result that the warning light is now off. Fingers crossed it stays off!
In case this helps anyone, it turns out that the part numbers for the coolant level sensor are different:
PCJ000050 for the Rover 45 and MG ZS
PCJ000040 (for Rover 25 and MG-ZR I think).
Cheers for all your help!
