1 - 20 of 27 Posts
Driving yesterday car suddenly seemed under powered. When I pushed accelerator down further to compensate whole car started to judder. Only seemed to happen over about 2500 RPM and no warning lights came on.
I thought clutch problem? and drove home.
Today Car won't start. When trying to start the moment the engine catches it cuts out. Engine warning light is on (can't remember if that comes on as a bulb test).
Whats the best way to get this fixed when I dont know what the problem is?
Thankyou 1000 times if you can help.
Chris
Rover 75 Conn 03 plate
The clutch shouldn't prevent the car starting if the car is in neutral.
What engine is on the car? Petrol? possibly the fuel filter has come apart.
Thanks for answering. I didnt think so either, but it seemed a bit much for a coincidence.
Its petrol 1.8 turbo. 26000 miles.
Oh no not the fuel filter that had to be done once already when the car was only a few months old - grr
I'd check that first unless it had the clip fitted at the time which should stop future problems.
Were the symptoms similar last time?
Discussion Starter · #5 · (Edited)
SORRY for my slow response.
That happened when I lent it to someone I dont know exactly how it went. I'm been trying to get through to him to ask.
Definitely trying to start in neutral, I just had another go.
Whining noise like a motor can be heard somewhere behind the glovebox area. Not noticed before but stereo would normally be on.
Would the juddering I felt fit with the fuel pump problem too?
THANKS in advance
Today I found plenum drain was full of water and cleared that and managed to make the car start - at last!
BUT
It was a very hesitant start. It kept searching for the idle speed and felt like it would stall any moment. I would have pulled the choke out if it had one, you know?
I kept it running for about 10 mins by keeping accelerator pressed in a bit. Eventually it idled roughly on its own. Promising. But after I switched off it wouldnt start again just like before.
I dont believe the fuel pump has dismantled itself as fuel clearly can get through at times
mg_zt
clutch problem?
Would reiterate to check the fuel pump/filter - had to replace mine last month and symptons were;
no power when driving
tickover all over the place
difficult starting
After repairing the filter with the recommended clip, car was back to normal AND seemed to have gained more power.
Would not have thought a clutch problem would give these symptoms.
Discussion Starter · #8 ·
difficult starting
Thanks for your story - how annoying I sympathise.
The clutch idea is out of the window now, I just didnt have enough experience.
I'm starting to think I am unlucky and the fuel pump has gone again. Still its lasted 3 years, which is longer than the first one did (9 months).
Discussion Starter · #15 ·
The space where the ECU sits has a little gunk at the bottom and the drain seemed partially blocked. I couldnt see any water there and it didnt look like the ECU had been wet.
Is it OK to disconnect the big ECU cables so I can get it right out for closer inspection? I don't want to do that if I need special equipment to set it up again when I reconnect it.
The ECU looks like a sealed up metal block, any tips for making sure its dry inside?
(Thanks again everyone for helping me with this, together we can avoid the big garage bill)
rover_75_tourer
ecu
DIssconect the battery first the ecu isin a plastic box if its wet inside remove from box and place in awarm place for a day or so and then reasemble the unit
rover_75_tourer
ecu
Yes a black plasic open ended box ecu is a silver box with all the plugs on ps make a note in which order you remove then if you dont then you cant get them back as you will find out
Fuel pump/Filter
:err: I'm thinking of replacing the fuel pump or trying the famous clip on it.
I'm trying to work out how easy this is for a total beginner....
I found this, particularly post #6
http://forums.mg-rover.org/showthread.php?t=151990
Is there a guide with pictures? The only pics I find links to don't exist anymore.
Neither does the PDF mentioned in post 3 :(
Chris. The fuel pump is under the drivers side of rear passenger seat. You can check its working by switching ignition to position 2 and listening carefully. It will usually run for up to 1 minute.
The fuel filter is under the left side (n/s) of the rear pass. seat. It is this that unscrews. Must be careful to position sealing rings correctly before screwing up tightly. It is at this point that the orange clip can be fitted to stop it happening again.
The underbonnet fuel pump will also run with ign. on & is positioned next to the battery.
Very late cars only have the rear tank pump.
1 - 20 of 27 Posts
