Noticed this morning that my clutch pedal has got some play in it. By that I mean I can depress it by hand for about an inch with no resistance then it operates as normal.
When using my foot when the resistance is met there is a clunk somewhere behind the steering column (sounds as if its coming from there anyway).
The clutch is behaving as normal, the gears are not grating and the bite seems OK. There is plenty of depth in the pedal still. I just don't remember it having that slop. Is it just a mechanical thing with the pedal or am in trouble?
Reason I ask is because last time I experienced this sort of thing was with a Landy that dropped its clutch fluid into the footwell when a cylinder failed.
I am hoping its just a pedal adjustment that is required. Will check the fluid level later today. I'm a bit busy at work atm.
