Ive got a vvc 160 that im going to fit into my rover 100.
Im going to be using an r65 gearbox with lsd and 1600 flywheel.
Can anyone recomend a good uprated clutch to use that will be fine for everyday use by be able to take some stick?
cheers
cheers
The standard clutch should be fine. As long as you treat it well. IE no riding the clutch for driving with your foot resting on the pedal.
This might be worth a look if you want more than OE..
http://www.ptp-ltd.co.uk/shop/ProductDetails.aspx?productID=642
Someoen in the F/TF section fitted one and they were happy with it.
europerformance do black diamond clutches - if you have got a flywheel from something like a bubble 216 then you need to get the clutch for the 1.4 or 1.6 - not the 1.8 as the mountings on the flywheel will be in a different place
